Wi-Fi connection Issues
You may have issues with the Wi-Fi connection between your inverter and your modem/router. As long as the other indicators on the inverter show “Normal” or “Generating”, a faulty Wi-Fi connection does not affect the electricity production or electricity sold back to the utility company.
There are several potential reasons for Wi-Fi issues. A common reason is that the modem/router has been replaced forgotten to set up the inverter to the new network, which allows it to communicate with the monitoring platform (www.semsportal.com) and the SEMS Portal APP). Another common reason for Wi-Fi issues is a weak Wi-Fi signal which is often due to the distance between the inverter and router. An unstable internet signal from the modem/router could also cause Wi-Fi issues.
The easiest way to identify Wi-Fi issues is to check what the Wi-Fi indicator on the inverter is showing. In the attachment “LED_explanation” there is a graphical explanation what the Wi-Fi indications mean and their associated error message.
In case there is no continuous Wi-Fi connection with the inverter, we recommend resetting the Wi-fi connection by starting the “Wi-Fi reload operation”. With the “Wi-Fi reload operation the current Wi-Fi settings on the inverter will be reset to factory settings and enable you to set up the Wi-Fi connection from start.
The instructions to use the “Wi-Fi reload operation” and reset the connection between the router and the inverter are provided in the attached file “WiFi ConfigurationInstruction”. Make sure to have the router password at hand and keep the mobile device used for the set up within 3 meters from the inverter during the setup.
 The link https://www.youtube.com/watch?v=a9m8tpNVhgs will lead you to just a very old video on how to set up the wifi.
    • Related Articles
    • XS remote shutdown connector
        The XS inverter supports the Remote Shutdown functionality. A connector is supplied for this, which must be connected regardless of whether the Remote Shutdown function is used. If the connector is not installed then the inverter will remain in ...
    • How to configure EZLoggerPro
        There are 2 options to connect the inverter(s) to EZLoggerPro: 1. Pull separate cables from separate inverter to Ezlogger and connect them to eg com1 and com2 2. Connect inverters wth the 2-wires RS485 cable, and then connect to EZLoggerPro   Then ...
    • Adjusting the price per kWh in the SEMS Portal
      You indicated that you want to change the price per kWh in your monitoring environment.   The price per kWh is used to calculate your income from the PV system and is displayed in the SEMS Portal. Usually, the price per kWh is set up during the ...
    • Transfer the SEMSPortal-account to a new owner
      If there is a new owner of the inverter and you wish to transfer the monitor account on SEMS Portal. There are 2 ways to transfer the monitoring account to a new owner or email: Option 1 (Transfer your account and the historical data) This option ...
