Transfer the SEMSPortal-account to a new owner
If there is a new owner of the
inverter and you wish to transfer the monitor account on SEMS Portal.
There are 2 ways to transfer the monitoring
account to a new owner or email:
Option 1 (Transfer your account and the
historical data)
This
option allows you to transfer your account to the new owner and allows them to
keep the historical generation data. To do this, log into your account on www.semsportal.com and
change the email address to the new owners email address.
Option 2 (Create a new account)
This option will create a new account for the
owner and erase the historical generation data for the plant. To create a new
account for an already registered inverter, it is necessary to send us a
picture of the label located on the side of the inverter. Note that the whole
label needs to be visible in the photo and the photo needs to be sent from the
e-mail address of the new owner. After receiving this, we will provide the
serial number necessary to link the inverter to the new account on the SEMS
Portal. The new owner can now register a new account and connect the inverter
via www.semsportal.com.
Please note that all historical data will be deleted and not visible to the new
owner with this option.
We hope this answers your questions and if you
need additional clarifications, please do not hesitate to contact us.
Related Articles
Change account for SEMS
You indicated that you want to change your e-mail address to which you receive your notifications from the SEMSPortal. To change your e-mail address in the SEMS Portal, you need to log in to www.semsportal.com with your old login credentials. After ...
Adjusting the price per kWh in the SEMS Portal
You indicated that you want to change the price per kWh in your monitoring environment. The price per kWh is used to calculate your income from the PV system and is displayed in the SEMS Portal. Usually, the price per kWh is set up during the ...
SEC1000: Inconsistent Load and Meter curves on SEMS
With the following instructions, you can check the Load and Meter curves on SEMS of your PV System equipped with a SEC1000. In case of an error installation of the SEC1000, you may observe the load and meter curve inconsistent on SEMS. See the ...
Wi-Fi connection Issues
You may have issues with the Wi-Fi connection between your inverter and your modem/router. As long as the other indicators on the inverter show “Normal” or “Generating”, a faulty Wi-Fi connection does not affect the electricity production or ...
How to configure EZLoggerPro
There are 2 options to connect the inverter(s) to EZLoggerPro: 1. Pull separate cables from separate inverter to Ezlogger and connect them to eg com1 and com2 2. Connect inverters wth the 2-wires RS485 cable, and then connect to EZLoggerPro Then ...
