RCR – Ripple Controle Receiver
Grid providers in some Markets (e.g. Germany for PV Systems >25kW or as requirement for state subsidies) require that PV Plants are controllable by them via RCR. Technically this is a small box with 4 Relays triggered by a simple form of PLC signal from the grid operator.
Figure 1 Rough schematic
EzLoggerPro and SEC1000 can be used to realize the multi-level throttling of PV power to 0% / 30 % / 60% / 100%.
Note: only works with PV inverters (no Hybrid or Battery inverters)
Figure 2 EzLogger Pro & SEC 1000 interfaces
Figure 3 RCR wiring to EzLogger Pro and SEC1000
Figure 4 Setup in ProMate
Workaround for hybrid and battery inverters
The DRM0 interface or the remote switch interface can be “misused” for the same purpose. With their help 0 % / 100% throttle can be realized.
For some DSOs in Germany this is acceptable.
Note: Clarify with DSO before installation if that is acceptable ( 0 % / 100 % instead of 0 %/ 30% / 60% / 100%.
    • Related Articles
    • How to configure EZLoggerPro
        There are 2 options to connect the inverter(s) to EZLoggerPro: 1. Pull separate cables from separate inverter to Ezlogger and connect them to eg com1 and com2 2. Connect inverters wth the 2-wires RS485 cable, and then connect to EZLoggerPro   Then ...
    • SEC1000: Inconsistent Load and Meter curves on SEMS
      With the following instructions, you can check the Load and Meter curves on SEMS of your PV System equipped with a SEC1000.    In case of an error installation of the SEC1000, you may observe the load and meter curve inconsistent on SEMS. See the ...
