Adjusting the price per kWh in the SEMS Portal
You indicated that you want to change the price per kWh in your monitoring environment.
The price per kWh is used to calculate your income from the PV system and is displayed in the SEMS Portal. Usually, the price per kWh is set up during the instalment of your system and first connection to the SEMS portal.
Of course, you can always change this price by logging in to www.semsportal.com with your account.
After logging in, go to ‘Management’ >> ‘Plants’ (from the side menu) >> select your plant name. Further down on this page is a field called “Profit Ratio” where you can change your price per kWh and the corresponding currency.
In the attachment you can also find the described steps.
Related Articles
Change account for SEMS
You indicated that you want to change your e-mail address to which you receive your notifications from the SEMSPortal. To change your e-mail address in the SEMS Portal, you need to log in to www.semsportal.com with your old login credentials. After ...
Transfer the SEMSPortal-account to a new owner
If there is a new owner of the inverter and you wish to transfer the monitor account on SEMS Portal. There are 2 ways to transfer the monitoring account to a new owner or email: Option 1 (Transfer your account and the historical data) This option ...
SEC1000: Inconsistent Load and Meter curves on SEMS
With the following instructions, you can check the Load and Meter curves on SEMS of your PV System equipped with a SEC1000. In case of an error installation of the SEC1000, you may observe the load and meter curve inconsistent on SEMS. See the ...
Wi-Fi connection Issues
You may have issues with the Wi-Fi connection between your inverter and your modem/router. As long as the other indicators on the inverter show “Normal” or “Generating”, a faulty Wi-Fi connection does not affect the electricity production or ...
PV Master Modes Explained
There are 3 kinds of Work modes available in the PV Master app: General Mode Back-up mode Economical mode General Mode The General Mode is the standard mode and is recommended in most situations. During this mode, self-consumption of the PV is ...
